Demon4x4.com • View topic - Kris Dana 44 Swap
Kris Dana 44 Swap
Kris Dana 44 Swap
Postby Kris Guilbeaux » Fri Feb 14, 2003 7:53 am
I Got some one that wants to sell me an EB Dana 44 with Disc Brakes and Radius Arms and Radius arm Brackets for $400 + Shipping is this a good Deal?
Re: Dana 44 help
Postby KF5ZXT » Fri Feb 14, 2003 8:09 am
That's usually what high pinion dana 44's go for. So I would say that it is a little high. It depends on what kind of shape it is in, and stuff like whether or not the gear ratio is to your liking. I have seen non-disc braked eb d44's go for $80 including the arms and coils on ebay. But that may have been without axle shafts.
But as they say, if it is worth it to you, then it's a good deal. ;) I spent a bit more than that for mine. :roll
Re: Dana 44 help
Postby Kris Guilbeaux » Fri Feb 14, 2003 3:59 pm
The thing I am thinking about is the Disc brakes. If I get one that is Drum Brakes I would have to convert it. Cant that get expensive?
Re: Dana 44 help
Postby Kris Guilbeaux » Fri Feb 14, 2003 4:13 pm
I just bid on a High Pinion one on E-bay. Hopefully I will win it.
Re: Dana 44 help
Postby KF5ZXT » Fri Feb 14, 2003 7:21 pm
Yes, adding disc breaks gets mucho expensive. That alone would probably cost 300+ So if you look at it that way, it's a good deal. Good luck on your auction.
Re: Dana 44 help
Postby Kris Guilbeaux » Mon Feb 17, 2003 3:34 pm
Well I got my Dana 44 complete hub to hub with 3.50 gears for $200.00 it is a High pinion from a 1979 f-150 So I need to cut it down. Any place yall might recomemden for cutting her down.
Re: Dana 44 help
Postby KF5ZXT » Mon Feb 17, 2003 6:07 pm
Texas Auto Gear does a good job. :) In fact, we just dropped off Michael's D44 this morning.
Re: Dana 44 help
Postby ExplorerSC » Tue Feb 18, 2003 6:27 pm
Congrats on the purchase!
Don't rush on those roof bars, Conyl might be able to get me some. Actually, he says his Navajo rack will work on mine but I don't think so, what do you think?
ExplorerSC
Re: Dana 44 help
Postby Kris Guilbeaux » Tue Mar 11, 2003 1:20 am
Ok,
I have my 44 planned out and I am Going to tear down the Housing and have TAG cut it down and I am going to put it together my self.
I plan to buy warn shafts and CTMs. Where is the best place to buy warn shafts and CTMs?
I have my Shopping list made out.
Right outer Right inner Left inner Left outer
38816 38810 39143 38816
9.72" 27.94" 18.31" 9.72"
This set up will be the Exact same width as Randall's 44
Re: Dana 44 help
Postby KF5ZXT » Tue Mar 11, 2003 6:38 pm
Buy your CTM's straight from
Not sure about the Warn's, but I'll look into it, since I need some too :roll
Re: Dana 44 help
Postby Kris Guilbeaux » Wed Mar 12, 2003 2:04 pm
hey Randall,
I was reading your Write up on the explorer forums. And in your Post you said that you cut your Housing down 5.85" When I took the Measurement of the Full with to EB Axleshaft the difference was 5.97" Is this .12" going to make a big difference. What amoutn should I have TAG cut the Housing down too?
Re: Dana 44 help
Postby Kris Guilbeaux » Wed Mar 12, 2003 2:16 pm
WOW I just found the Price on the CTM U-joints. that is a lot!!!! I payed not much more then that for my whole dana 44
Re: Dana 44 help
Postby KF5ZXT » Wed Mar 12, 2003 7:36 pm
You didn't know they were $185? I'll probably still get them :)
Yes, I cut mine down 5.85. You, however, should cut yours down 5.97, so you can use eb shafts. I was given bad information when I had mine cut, and instead had it cut to an eb d30 axle, which is where 5.85 comes from. I now have to get a custom shaft made on the passenger side, discouraging, since that was what I was trying to avoid in the first place.
Re: Dana 44 help
Postby Kris Guilbeaux » Thu Mar 13, 2003 11:29 am
Thanks Randall,
If I have the Extra $400.00 when I start putting the Axle together I will install CTMs but I dont I just going with the Warn Shafts and forget the CTMs The High Steering and a few other things are going to happen First.
Re: Dana 44 help
Postby Kris Guilbeaux » Wed Mar 19, 2003 3:18 pm
My Axle is ready to go get cut down.
Re: Dana 44 help
Postby KF5ZXT » Wed Mar 19, 2003 4:57 pm
Damn, that thing looks brand new. I got my high steer arms in today...
Re: Dana 44 help
Postby Kris Guilbeaux » Wed Mar 19, 2003 5:06 pm
just trying to keep up with what you said that one time. If I Own it it looks new. ;)
So when are they going to be installed?
Re: Dana 44 help
Postby KF5ZXT » Wed Mar 19, 2003 5:19 pm
I'm still waiting on my Knuckles, and then I need to measure it up for steering linkage, before I order some from Rockstomper.com
Re: Dana 44 help
Postby Kris Guilbeaux » Mon Mar 24, 2003 8:57 pm
Hey Randall,
What time does Tag Close on Saturday?
Re: Dana 44 help
Postby KF5ZXT » Tue Mar 25, 2003 1:05 am
I wouldn't really say that they have set closing times, but I would try to be there before two or so. Best thing would probably be to call ahead. Unfortunately, I have to work this Saturday :(
My knuckles came in today :)
Re: Dana 44 help
Postby Kris Guilbeaux » Tue Mar 25, 2003 8:10 pm
What do you work on Saturday? Hmmmm I might just have to wait till next Saturday.
Re: Dana 44 help
Postby KF5ZXT » Tue Mar 25, 2003 9:19 pm
they started some new thing where the receivers have to rotate saturdays, due to the large amount of outdoor lawn and garden trucks we have been getting.
Re: Dana 44 help
Postby Kris Guilbeaux » Tue Mar 25, 2003 11:35 pm
That sucks I started this Week and they were soo happy Up Front they said they have been needed some one good to work up front. During Orintation I was Told we are getting 7 Trucks a Week right now and Lawn and Garden is as sniffing glue as it can get... From what I am use to Head Cashier is going to be simple.
I will see what kind of schedule I get this next week and I will see when you and me can run up there.
Re: Dana 44 help
Postby KF5ZXT » Wed Mar 26, 2003 12:03 am
That's one thing you'll have to get used to. Everyone on the floor only counts the distribution trucks as 'trucks' so saying seven a week doesn't sound like a whole lot, but we usually receive 25-35 trucks daily. Since I have to work this saturday, I will be getting a day off during the week next week. Let me know what days you are off and we'll try and swing something.
Re: Dana 44 help
Postby Kris Guilbeaux » Wed Mar 26, 2003 1:44 pm
I am Going to be off Tuesday and Wednesday.
