Demon4x4.com • View topic - *** Lift Question ***
Postby SVO » Wed Jul 09, 2003 6:14 am
Ok guys, I may beable to pull this off before Gilmer but I need to know the part numbers and basic part prices for what I need: (1992 Navajo/Explorer 2dr)<br><br>5" Super lift brackets for the front w/harware<br><br>Coil springs<br><br>Shocks<br><br>Drop pitman arm<br><br>Steering dampener<br><br>Front/rear brake lines<br><br>OAS axle perches<br><br>Wheel offset and width for new wheels<br><br>Rear axle pinion angle for new set up.<br><br>Anything else you might think of I'll need<br>I already have 4dr rear leaf springs too.<br><br>If you know of someone who might have this stuff used in good condition w/harware I be will to consider that too.<br><br>Sorry to sound like a newbie but I am, guess it's time to "grow up", plus I'm trying to minimalize down time.<br><br>What about a semi locker for the front Dana 35? (powertrax)<br><br>4.56 gears front and rear? who's got a good price on these.<br><br>If you give me part numbers, that way I know I'm getting just what I need, what about your 4WD guy there in Houston that Michael used would he give me a package deal, I don't mind driving down there. (give him this list)<br><br>Like to pull this off before Gilmer and suprise everyone, or at least try too!<br><br>thanx! for all your help.<br> <p></p><i>Edited by: <A HREF=http://pub182.ezboard.com/bdemon4x4.showUserPublicProfile?gid=specialvehicleoperator>Special Vehicle Operator</A> at: 7/9/03 7:21 am<br></i>
SVOC Federation of Techno-ology
Official copious user of the :finger
SVO
Re: *** Lift Question ***
Postby Michael » Wed Jul 09, 2003 8:50 am
5" Super lift brackets for the front w/harware<br>Coil springs<br>Shocks<br>Drop pitman arm<br>Steering dampener<br>Front/rear brake lines<br>OAS axle perches<br>------------------------------------------------<br>These should come in any "lift kit" that you buy over the counter. Superlift and Skyjacker both offer the 5-6 inch lift. For wheels I am in favor of 15X8 for a 33 inch tire. 3.5-3.25 backspace will put them even with or just outside the fender and should minimize trimming needed. I have the 15x8 MickeyThompson Classic II's that were on my truck before the SAS sitting in my garage needing a new home<!--EZCODE EMOTICON START ;) --><img src=http://www.ezboard.com/images/emoticons/wink.gif ALT=";)"><!--EZCODE EMOTICON END--> . They are a little rough but still decent. Pinion angle should stay the same with the spring over, you don't have a CV joint in the rear shaft right?. The new perches get welded on parallel to the old ones. I would definately go 4.56, as far as prices I can't help on that. When I did my original build up I sourced everything through a shop here, not Texas Auto Gear. I payed a little more, but I am loyal like that. This is a little out of Texas Auto gears element. They are more custom oriented, and you will pay a lot more than if you get it all yourself. For a front locker I ran a Detroit EZ locker that I got at 4Wheel Parts. It and the Lock Right both list about $250. If you have an open rear carrier on your lot you can get a lock Right for the rear as well at about the same price versus 400 for the No Slip for the trac lok carrier.<br><br>I think I got it all covered, but if it is not clear ask again<!--EZCODE EMOTICON START :D --><img src=http://www.ezboard.com/images/emoticons/happy.gif ALT=":D"><!--EZCODE EMOTICON END--> <p></p><i></i>
Michael B
Jeep Wrangler Rubicon
Michael
Demon Reverto
Postby Sexy Evil ST » Wed Jul 09, 2003 9:12 am
Jeff,<br><br>Don't you want to get some Warn manual hubs too. <br>Last weekend it seemed you were going through autohubs like underwear. And you were all stock. <br>Adding larger tires and a locker might make you go through autohubs like beer.<br><br>Just a thought. But the other guys on this board will know better than me, since I'm just a no hub kind of guy. <p></p><i></i>
It's hard out here for a chimp!
Sexy Evil ST
Postby SVO » Wed Jul 09, 2003 10:50 am
John:<br><br>The manual hubs are a given and I pretty much have that on lock down.<br>But your right the auto hubs are junk, I'm suprised I didn't break that last set on that climb.<br><br><br>Michael:<br><br>Are the wheels you have BLACK????<br>And I too was am into supporting the reputable businesses.<br>33's were about what I wanted to go with, I hear way too many problems with bearings and 35's. <p></p><i></i>
SVO
Postby SVO » Wed Jul 09, 2003 2:56 pm
I have a 1994 4dr 4x4 Explorer, it's back in your court sir.<br><br>That's the newest year that'll fit your application.<br> <p></p><i>Edited by: <A HREF=http://pub182.ezboard.com/bdemon4x4.showUserPublicProfile?gid=specialvehicleoperator>Special Vehicle Operator</A> at: 7/9/03 4:02 pm<br></i>
SVO
Postby Michael » Wed Jul 09, 2003 3:16 pm
No, they are aluminium with holes in them. <br><!--EZCODE AUTOLINK START--><a href="http://www.mickeythompsontires.com/wheels.html">www.mickeythompsontires.com/wheels.html</a><!--EZCODE AUTOLINK END--><br>I was just throwing them out there in case you were interested. I can understand wanting black ones. I switched. <p></p><i></i>
Michael B
Michael
Demon Reverto
Postby SVO » Wed Jul 09, 2003 3:28 pm
I'm quite interested, shoot me the numbers please! <!--EZCODE EMOTICON START :) --><img src=http://www.ezboard.com/images/emoticons/smile.gif ALT=":)"><!--EZCODE EMOTICON END--> <p></p><i></i>
SVO
Postby Michael » Wed Jul 09, 2003 3:47 pm
What's a set of newish 4 door leaves worth? Possible trade? <p></p><i></i>
Michael B
Michael
Demon Reverto
Postby Michael » Wed Jul 09, 2003 4:22 pm
I was thinking $150 for the wheels. Like I said they are a little rough. There are a few scratches in the out lip of each one from rocks and some in the inner surfaces, but they should still clean up and look good. I am willing to trade for the leaves. <p></p><i></i>
Michael B
Michael
Demon Reverto
Postby SVO » Wed Jul 09, 2003 4:33 pm
Done! When do you want the springs sir, I'll even deliver them. <p></p><i></i>
SVO
Postby KF5ZXT » Wed Jul 09, 2003 6:44 pm
If you're looking to get the lift new, the cheapest place that I found it back when I did my 5.5" superlift was at <!--EZCODE LINK START--><a href="http://tyres1.com">tyres1.com</a><!--EZCODE LINK END--> but it doesn't look like they have skyjacker.<br><br>I'd order it without shocks and get some Rancho RS9000's so that you won't need sway bars. It comes with drop brackets, drop pitman arm, coil springs, sway bar drop brackets, shocks, and SOA axle perches. The shocks are pretty much junk though. Tyres1 has the superlift kit for 645 with shocks, you'll have to call and ask the price without. Also get the extended brakelines. I'll get the part numbers for the Rancho shocks that I used with my 5.5 lift when I get home. You may want to measure for yourself, but at least it will give you a starting number.<br><br>If you need help with the install, I wouldn't mind lending a wrench or two <!--EZCODE EMOTICON START ;) --><img src=http://www.ezboard.com/images/emoticons/wink.gif ALT=";)"><!--EZCODE EMOTICON END--> <br><br>Oh yeah, I would also recommend extended radius arms, but they can always be added on later. SkyJacker arms are better than superlift. <p></p><i>Edited by: <A HREF=http://pub182.ezboard.com/bdemon4x4.showUserPublicProfile?gid=demon4x4>Demon4x4</A> at: 7/9/03 7:53 pm<br></i>
Postby SVO » Wed Jul 09, 2003 8:44 pm
What about these?<br><br><br><br><!--EZCODE AUTOLINK START--><a href="http://www.explorerforum.com/forums/showthread.php?s=&threadid=82839">www.explorerforum.com/for...adid=82839</a><!--EZCODE AUTOLINK END--> <p></p><i></i>
SVO
Postby KF5ZXT » Wed Jul 09, 2003 10:01 pm
I lack original thought, they look kind of weird. You can't get much use out of them without the mounting brackets. So if you can get Rancho to send you the brackets, or make your own, then go for it. Otherwise, I'd keep looking. <p></p><i></i>
Postby KF5ZXT » Wed Jul 09, 2003 10:25 pm
check this out: <!--EZCODE LINK START--><a href="http://explorerforum.com/forums/showthread.php?s=&threadid=82907">explorerforum.com/forums/showthread.php?s=&threadid=82907</a><!--EZCODE LINK END--><br><br>That's a good price, it includes the superrunner steering upgrade as well as the extended radius arms. <p></p><i></i>
Postby SVO » Thu Jul 10, 2003 5:01 am
That's what I'm talking about, the only reason that I was looking at thoes arm were that he had a really cheap price on them, but I guess now I know why. <!--EZCODE EMOTICON START :o --><img src=http://www.ezboard.com/images/emoticons/embarassed.gif ALT=":o"><!--EZCODE EMOTICON END--> <br><br><br><br>So you got the RS9000's for a 5" lift in the front then used the stock ride RS9000's for the rear and just mounted them to the sway bar location correct? <p></p><i>Edited by: <A HREF=http://pub182.ezboard.com/bdemon4x4.showUserPublicProfile?gid=specialvehicleoperator>Special Vehicle Operator</A> at: 7/10/03 6:41 am<br></i>
SVO
Postby Michael » Thu Jul 10, 2003 8:36 am
check this one, only a 4 inch kit as opposed to a 5.5, bt you should still be able to fit 33 with some trimming.<br><br><!--EZCODE AUTOLINK START--><a href="http://66.227.24.111/forums/showthread.php?s=&threadid=82316">66.227.24.111/forums/show...adid=82316</a><!--EZCODE AUTOLINK END--><br> <p></p><i></i>
Michael B
Michael
Demon Reverto
Postby KF5ZXT » Thu Jul 10, 2003 3:57 pm
I got them for a 6 inch lift since I got the spacers at the same time. The rear shocks were 9112's which are pretty close to stock length. <p></p><i></i>
Postby KF5ZXT » Fri Jul 11, 2003 7:26 am
I say go with the 35's and a little trimming. I wouldn't worry about the bearings and stuff in the d35, since you plan on doing a SAS anyway <!--EZCODE EMOTICON START ;) --><img src=http://www.ezboard.com/images/emoticons/wink.gif ALT=";)"><!--EZCODE EMOTICON END--> Michael ran 35's on the TTB for a long time and never had any real issues with them, other than having to tighten the spindle nuts frequently. Eventually he burnt out a spindle, but you wouldn't have any trouble finding those. <br><br><!--EZCODE QUOTE START--><blockquote><strong><em>Quote:</em></strong><hr><!--EZCODE ITALIC START--><em>Originally posted by SVO</em><!--EZCODE ITALIC END--><br>33's were about what I wanted to go with, I hear way too many problems with bearings and 35's. <hr></blockquote><!--EZCODE QUOTE END--> <p></p><i></i>
Postby SVO » Fri Jul 11, 2003 7:28 am
Michael, <br><br> I'll even throw in a driver's rear glass for you too. <p></p><i></i>
SVO
Postby Michael » Fri Jul 11, 2003 11:01 am
There is one sitting in my garage already. I just haven't had time to put it in yet. If you are looking to throw more stuff in, a set of ranger leaves would be cool so that I can add the main leaf to my ex pack. If i need to toss in some cash in addition to the wheels let me know. Like Randall said above, if you want help with the lift install let us know, I did one on a previous truck. <p></p><i></i>
Michael B
Michael
Demon Reverto
Postby SVO » Fri Jul 11, 2003 4:45 pm
They unfortunatly they won't let me split a spring pack, but I have these springs here, if you would like I can bring them to you on like Sunday if you like, all you have to do is let me know.<br><br>254-715-7361 <p></p><i></i>
SVO
Postby Michael » Sun Jul 13, 2003 4:15 pm
We can set something up. Is it looking like you are going to get your lift and stuff done in time for Gilmer? If not I can bring the wheels to you there and swap them for the springs. If you need them before that it can be arranged. <p></p><i></i>
Michael B
Michael
Demon Reverto
Postby KF5ZXT » Tue Jul 15, 2003 6:54 pm
Hey Jeff, if I were you I'd pass on the front traclok for $140. You could get a full locker for $250 (ezlocker, or lock right) that would perform a lot better than the trac lok. If you're going to do it, do it right. Put in lockers front and rear. Just my opinion, of course. <!--EZCODE EMOTICON START ;) --><img src=http://www.ezboard.com/images/emoticons/wink.gif ALT=";)"><!--EZCODE EMOTICON END--> <p></p><i></i>
Postby SVO » Tue Jul 15, 2003 8:34 pm
Who has the "ezlocker" for $250?<br><br>Man I need to figure out where you guys are getting this stuff.<br>I really didn't think the $140 was bad, but I also didn't want all that wind-up when turning either, but belive me I do see your point.<br><br>Still not sure if I'm gonna be able to pull off the lift by Gilmer, it would be nice to suprise everyone though, I have just so much on my plate right now.<br>Not just work but my personal life just blew-up too, way too long to type I'll just chat about it over a warm camp fire and some ice cold beers one night. <p></p><i></i>
SVO
Postby Michael » Wed Jul 16, 2003 9:28 am
EZ Locker and Lock Right can both be found at 4Wheel Parts in the 250 range. I had the EZ Locker, Kris G still has the EZ Locker. It has an effect on turning in the rocks, but it is something that you get used to. It won't take you long at all to learn how to modulate the throttle to get the locker to unlock so you can turn. <p></p><i></i>
Michael B
Michael
Demon Reverto
Users browsing this forum: No registered users and 2 guests
